Vented and drill disc for up grade?
markus_74
Post Wed Dec 18, 2013 3:51 pm
helllo, need advice
can I use vented and drill disc on my 318i sedan/limousine to upgrade ? I found some good pagid brand brake disc.
thank you
capnmchl
Post Wed Dec 18, 2013 4:05 pm
You can't use the vented discs unless you have calipers for a vented disc.
Drill holes are just pointless and cause more hassle than they solve.
markus_74
Post Thu Dec 19, 2013 3:11 am
thank you capnmchl
Billwill
Post Thu Dec 19, 2013 7:42 am
Use good quality disk pads and rear shoes and the 318i has adequate stopping power! :wink:
G-Bear
Post Thu Dec 19, 2013 10:54 am
Pagid discs and pads are good. A calliper overhaul with new seals usually improves things...
http://www.e30zone.net/e30zonewiki/inde ... er_Rebuild
