dismantling / taking apart headlight
JM2012
Post Fri Nov 29, 2013 11:15 pm
How is the glass of the headlight held in place/how do I remove it?
This picture shows them dismantled but on realoem they appear to be sealed?
Cheerz,
Jon
Cloggy Saint
Post Fri Nov 29, 2013 11:17 pm
The glass is bonded on. You need to apply heat to loosen the bond and then carefully prise it off.
The lens are glued on. Use a heat gun and gently heat up the glue. Keep going round the light to avoid melting the plastic.
Should pull apart after that.
JM2012
Post Fri Nov 29, 2013 11:20 pm
Ah, ok guys, thanks.
Any preferred types/brands of glue to reinstall?
