E30 Baur Low beam / rear fog problem
emel
Post Fri Nov 29, 2013 10:52 am
The low beam on the headlights has ceased to work,along with the rear fogs.Fuses all look good,pulled the 5 pin K4 relay out replaced it with another spare,side and low beams came on as they should,but the sides stay on until the ignition is switched off.Rear fog still not lighting up.Replaced the fog K8 relay.There are no other electrical issues.
The car 1999 e30 Baur TC.
