running to rich and running ruff
danny314
just brought a another 2.5 coupe its running very rich 20quid 30miles brought from a close friend its had a full service and the cam sensor and idle sensor replaced 1 months ago when started cold it idles ruff and a strong smell of fuel best things to check or suggests
Grrrmachine
- E30 Zone Wiki / Team Member
An E30 has neither a cam sensor or an idle sensor (whatever that is), and a smell of fuel can indicate rich running, lean running* or a simple leak.
What makes you think it's running rich?
*If the mixture is too weak for the plug to ignite, it will pass out of the exhaust as liquid fuel.
