Cambelt time
stu328is
Post Mon Nov 18, 2013 1:37 pm
My car will be going into a garage this week for a few bits and I am supplying the parts and just need some confirmation with bits needed, will be getting them from ecp but need some help getting the right bits, it's a g plate 325i
Any difference in quality from these 2 and is that all they guy will need to do it?
http://www.eurocarparts.com/mobile/timing-belt-kits
Also doing water pump while its all apart but have 3 choices so not sure which one and if I'll need the gaskets or if they come supplied?
http://www.eurocarparts.com/mobile/water-pump-gasket
Anything else I should do while they have it in bits??
Also I'm having the rear axle bushes done will 2 of the below be all be needs to that??
http://www.eurocarparts.com/mobile/ecp/ ... 2df&000273
Just don't want the job delayed because of wrong bits or missing parts
Cheers for any help
E36 328 Sport
E30 325i
Mk2 Golf 8v
Post Mon Nov 18, 2013 1:50 pm
Either brand is good on the cambelt. Probably worth getting a fan belt and pas belt while you are at it. I use KWP water pumps and have NEVER had a prob or comeback Lemforder subframe bushes are OE so no probs there.
The delays will usually caused by all the missing/broken / foooked related bits :(
Post Mon Nov 18, 2013 2:09 pm
If you decide on a BMW water pump, they give you a rebate on your old one, even if it's a non-genuine part - usually about £20 off. :wink:
Post Mon Nov 18, 2013 2:27 pm
Speedtouch wrote:If you decide on a BMW water pump, they give you a rebate on your old one, even if it's a non-genuine part - usually about £20 off. :wink:
Its a shame , even after the 'rebate' the pump from BMW will cost you more than ALL of the other bits together !
Post Mon Nov 18, 2013 2:33 pm
I've bought a couple, for the M20B25 and M30B35 - they were only about £80 each, not too bad for a genuine part that will last at least 3 years or so.
You take your chances with cheap water pumps - I've heard of some lasting less than a year, and given that they are a PITA to replace, you are better off getting a decent quality one.
Post Mon Nov 18, 2013 2:36 pm
Speedtouch wrote:I've bought a couple, for the M20B25 and M30B35 - they were only about £80 each, not too bad for a genuine part that will last at least 3 years or so.
That's why you buy a KWP pump. No aggro, no dramas , much cheapness :)
stu328is
Post Mon Nov 18, 2013 2:55 pm
Where do I get a kwp one from don't think ecp stock those, only circoli and one with no make on the listing
E36 328 Sport
E30 325i
Mk2 Golf 8v
Post Mon Nov 18, 2013 3:03 pm
My local Euros stock KWP , in a red and white box IIRC.
stu328is
Post Mon Nov 18, 2013 3:43 pm
Ok I'll have an ask when I'm down there, if I end up with a different make do I need to buy gaskets and stuff or should it all come with the pump?
E36 328 Sport
E30 325i
Mk2 Golf 8v
Post Mon Nov 18, 2013 3:44 pm
Gasket SHOULD be in the box BUT be sure to check before leaving !
stu328is
Post Mon Nov 18, 2013 4:17 pm
Nice one, cheers for all the help
P.s Pete have you got an alpine 11 drivers door for sale for a 2dr?
E36 328 Sport
E30 325i
Mk2 Golf 8v
stu328is
Post Tue Nov 19, 2013 11:51 am
I've had a quote from the garage I use and to do cambelt and water pump and change the bushes
Does £300 sound reasonable?
E36 328 Sport
E30 325i
Mk2 Golf 8v
Post Tue Nov 19, 2013 11:55 am
Sounds reasonable to me (it would probably take a full day at least to do that little lot), and yes, those Lemforder subframe bushes are OEM quality.
Rtaylor2208
Post Tue Nov 19, 2013 12:01 pm
The bushes will push up the labour time, but the belt and pump should be feasible in 2 to 3 hours for a mechanic knowledgeable about the M20 engine.
As mentioned above whilst doing the belt change your other v belts too, I would also replace the belt tensioner, the spring and pin used with the tensioner if your not sure the last time it was done.
stu328is
Post Tue Nov 19, 2013 12:08 pm
He's said should be 4hrs or there abouts for the lot, does the kit not come with the spring and pin, it comes with the new tensioner so is that not included?
Can't bloody wait for the bushes to be done the back end feels awful at the moment, it's that bad I thought the spring was snapped before it got looked at, driving round like miss daisy at the minute lol
E36 328 Sport
E30 325i
Mk2 Golf 8v
Post Tue Nov 19, 2013 12:24 pm
No, quite often the tensioner doesn't come with the spring and pin - I had to re-use my old one.
It's usually just the pulley bearing that wears out though.
Post Tue Nov 19, 2013 12:31 pm
I have never seen a worn out spring or pin. I have seen a few MIA though ! :eek:
stu328is
Post Tue Nov 19, 2013 12:53 pm
Well, all booked in for Tuesday fingers crossed it'll all go ok
Thanks for everyone's help
E36 328 Sport
E30 325i
Mk2 Golf 8v
stu328is
Post Fri Nov 29, 2013 9:28 am
Got the car back and can't believe how much difference it's made, car feels quicker than it did before like the tyres were low before and my diff whine is nowhere near as noisy as it was before, could all be in my head if course lol
E36 328 Sport
E30 325i
Mk2 Golf 8v
