E30 ca18det convertion
bumchin318i
Post Thu Nov 14, 2013 7:30 pm
Any one converted a e30 with the ca18det ? My engine and box is going in Xmas when works gone quiet just not sure what diff to use before I get my prop done any ideas ? What ratio would be best for the job
age
Formerly twist316
Post Thu Nov 14, 2013 8:15 pm
Whats the car for? Drift or road?
M40 rightness if you can get to 6000rpm noone can hear your tappets
jamie-o-connell
Post Thu Nov 14, 2013 10:12 pm
Why bother going ca18det? You might aswell go sr20
GB69
Post Thu Nov 14, 2013 10:15 pm
These people have done it before https://www.facebook.com/slidemotorsport
As they can be modded to over 200bhp, I'd go for a medium case diff, from a 325 3.64:1, or touring 3.91:1.
GB69
Post Thu Nov 14, 2013 10:17 pm
Ianb
Post Mon Nov 18, 2013 9:45 am
I'm just finishing one off now. We're using a 3.91 diff that came off my old 316 auto. It's quite an easy swap, the only real issue was the servo and master cyl to exhaust manifold clearance. We've used a mk 1 golf servo and e30 master and will be making a heat shield. it's running a saab front mounted intercooler and i believe the rad is the original ca18 one. The prop is an e 30 rear half and centre joint with nissan front sect ( welded just after middle joint).
