My car needs new suspension bushings, shocks, new tie rods, steering column bushes and subframe bushes.
I also want to replace the front control arm "lollypop" bushings with the E30 M3 eccentric ones.
Along with these I want to do a few other mods and updates including replacing the dual mas flywheel with an m20 325 one and the Z3 shifter conversion.
Can you please give me a price for my shopping list:
Z3 Gear lever #2511 7 527 252 - Qty 1
Gear lever bush/bearing #2511 1 220 600 - Qty 1
Plastic yellow washer #2511 1 220 439 - Qty 2
Circlip /Spring clip #2511 7 571 899 - Qty 1
Offset e30 m3 eccentric front bushes
M42 cam chains and sprockets
M-Tec shocks,
New tie rods,
Steering column bushes
Water pump
Thermostat
325 Clutch
325 Pressure Plate
325 Drive-pinion for the Starter Motor
1978 to 1983 year '323i Throw-out' bearing.
Ball joints
Sorry for the long list but I would like a breakdown with prices for each so that I can prioritise cost if it gets too expensive.
Saved from the wrecking ball - restoring my M42
Cotswoldbmw
Hi Your quote as been looked at by stuart.
regards
Paul.
regards
Paul.
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
NoTurbo
Hi thanks for that
we are in contact by email.
Cotswoldbmw
Yes no probs.
Cotswold BMW Parts
01242 335365
01242 335365
