Fuel mixture?
- Brianmoooore
Spec. is 0.7, so looks close enough to me! In any case, if this kind of thing is out, it indicates a fault somewhere which needs sorting, not introducing another fault (moving factory adjustments) to compensate.
That sounds close enough to me! I was brought up on minis and mk1 golfs mainly so adjusting the mixture has been the norm, but the maf is a sealed unit so you're probably right that I shouldn't start playing about with it.
Thanks Brian!
Thanks Brian!
