Something I've not really thought about but is it as simple as swap the engine and box complete with ECU and auto ECU (in the boot)
I presume the prop is different and I might want to change the diff also. The switch for switchable auto also I assume.
But is it plug and play like swapping manual conversions?
I've got the 325 running gear
thanks
318 auto conversion to 325 auto
In a word, yes. Just note carefully how the loom fits when removing it from the 325.jimbom30cab wrote:
C101 pin 20 wiring warning applies.
jimbom30cab
- Tech 1 freak
Thanks Brian, will do
