Changing back to standard suspension...............
greentouring
Post Tue Oct 29, 2013 5:41 pm
I have a 316i Touring with a 70/50 lowering kit.
I now have to use my car for work which involves carrying heavy loads, so need her back to standard, or at least not so low that the wheels foul the arches under a full load. Also, I cannot stand the uncomfortable, bumpy ride on the country roads where I live (full of pot holes!).
Can anyone tell me if I can keep the up-rated shocks I have fitted and fit standard touring springs with them, or do I need to change the shocks back to standard if I go this route?
Another alternative would be to fit some lower springs that just aren't as short, but again, could I use these with the shocks that came with my current 70/50 lowering kit?
Any advise would be appreciated. TIA
DHFiS
Post Tue Oct 29, 2013 6:34 pm
I would fit standard dampers with standard springs if you want to have the full range of movement in the suspension.
**BANNED**
Post Tue Oct 29, 2013 10:58 pm
At a guess you will have shorter than standard dampers,which will not work properly with standard length springs.
A compromise that you may like to try would be M-tec front springs(-15mm)with standard rear springs damped with Borge gas dampers to M-tec spec,this should offer both decent load carrying with a firmer than standard ride.
Youth is wasted on the young.
greentouring
Post Wed Oct 30, 2013 10:13 am
Thanks for the replies guys, I think I'll go completely standard as BMW intended it to be.............I must be getting old to have said that!
