Where's the best place to purchase Piston Rings and Main/Big end bearings from?
What manufacture is recommended?
Crank will be grinded and I am told that I would need 0.25 size bearings?
I guess the Rings will be standard size?
Rings and Bearings
SilverShadow
- Hartge Crew
Whats peoples thoughts of ordering the parts from C3 BMW?
harry_p
C3 are fine. I've bought bits from there in the past, some have been genuine bmw, other bits oe manufacturers like febi, or decent aftermarket.
cheers,
harry
harry
SilverShadow
- Hartge Crew
In terms of price, should I bother researching else where?
- E30 Zone Meets/Events Team
Try "Maggspower" on here.
He sourced me piston rings and bigend shells for my M30
powelly
Any machine shop should be able to supply. It's the norm for the guys grinding the crank to supply shells as well
To give an idea bmw rings are £30 per set and the shells are about £10 each but the thrust washers are more like £25 so that's the most expensive route
Le Mans Classic 2006
