ABS Light??
bullitt
Post Tue Dec 20, 2005 7:03 pm
Hi Folks..
My 87 sport has been in storage for 18mths, i fired it up at the weekend and the ABS light is lit?
Any ideas..
Car is driving 100%..
Thanks...
kam-325i
Post Tue Dec 20, 2005 8:37 pm
Is the light staying on from turning the ignition on or is it coming back on after you have pulled off/gone above 10Mph ?
bullitt
Post Fri Dec 23, 2005 5:16 pm
The ABS light stays on even when driving??
A1BMW325iSport
Post Fri Dec 23, 2005 10:45 pm
most likely dirt/corrosion on the pickups give the sensors and pickups a clean
Jon_Bmw
Dangerous when thinking
Post Sat Dec 24, 2005 12:26 pm
Bullit if you explain how the abs light is coming on it would help us help you.
Right...
Does the light come on when you have the ignition on?
Does the light go out when you start the car or does it stay on?
If the light went out when you started the car does it go on when you reach a particular speed(5mph probably)?
The more info you give the more chance we have of helping :D
bullitt
Post Thu Dec 29, 2005 5:08 pm
Jon_Bmw wrote:Bullit if you explain how the abs light is coming on it would help us help you.
Right...
Q1 Yes..
Q2 Light stays on..
I will check the sensors and clean the pickups..
Thanks Folks..
