MY E30 V8 A FEW PICS
m340
Sun Oct 20, 2013 8:35 pm
Hi all, as promised in my other thread here of some pics of my e30. She is a 4.0 with a 6 speed manual.
[/img]Image
[/img]Image
[/img]Image :D :D
jimbom30cab
Tech 1 freak
Sun Oct 20, 2013 8:37 pm
very nice
is that using the hydraulic booster set up rather than a servo ?
would you have any details of it ?
thanks
TPS
Sun Oct 20, 2013 8:44 pm
Very Nice
Nobby_N
Sun Oct 20, 2013 8:52 pm
I like that and the merc!
Andy325i
Sun Oct 20, 2013 8:54 pm
VERY nice! I bet that goes like Stink! :D
m340
Sun Oct 20, 2013 10:21 pm
Thanks for the kind words guys, this is my first bmw so it's been a learning curve!
jimbom30cab - She is running the hydraulic booster, I've used all the parts from the donor 540i except the pipework which had to be custom made. I've used the 540i linkage rod to go from the pedal to the original e30 servo mount, which has been moved about 5 inches further towards the a pillar. Then the original e30 bulkhead linkage rod has been cut down, and used to join that to the hydroboost unit. If I can be of any help please get in touch.
Nobby_N - Thanks, the merc is another of my projects, 3.6 24v with an albrex blower waiting to be fitted.
Nobby_N
Sun Oct 20, 2013 10:22 pm
C36 are one of my fav mercs along with e55! Proper mercs but abit rusty lol
jimbom30cab
Tech 1 freak
Sun Oct 20, 2013 10:23 pm
thanks mate, very very nice job :cool:
come on then, tell us all how she drives and don't spare the detail !!
Phill172
Sun Oct 20, 2013 10:28 pm
Thats a nice install
I like the brake set up, i very nearly went for that myself
What engine mounts did you use?
m340
Sun Oct 20, 2013 10:46 pm
Nobby_N wrote:C36 are one of my fav mercs along with e55! Proper mercs but abit rusty lol
They do rust well. She's a bit earlier than those, 88 w124 e class, and it's a manual! 8)
GB69
Sun Oct 20, 2013 10:54 pm
Looks well tidy. Did you get a prop custom made, if so how much as I'll be getting mine done next week.
m340
Sun Oct 20, 2013 11:09 pm
jimbom30cab wrote:thanks mate, very very nice job :cool:
Cheers!
To be honest she drives like a 540, albeit a very lively one. It has a "big car" feel to it now, nothing like it was when I first drove it with the original m20 in there.
1st gear is useless as it just spins the rear wheels with a hint of throttle, so I start in 2nd. The engine seems to come alive at around 4000rpm and just want's to get me a speeding ticket! I haven't had her flat out yet, but I did manage to get her just off the clock on a local "de-restricted" section of bypass. The engine sounded glorious too!
The brakes work very well, and with the grip from the fat tyres she will stop quite violently. The front suspension is a little hard but other than that it feels planted.
Phill172 - The engine mounts are custom made by me, 8mm steel plate offcuts from a local metal firm that I welded together.
[img][img]http://i1248.photobucket.com/albums/hh4 ... fe44a1.jpg[/img][/img]
GB69 - Thanks.
The propshaft is from the 540, I shortened it in 3 places and welded the e30 rear coupling on the end. A loal firm charged me £50 to balance it.
Andy325i
Mon Oct 21, 2013 11:39 am
Epic Welding skills :D
E30Ad
Tue Oct 22, 2013 12:05 am
Simply superb mate - lovely motor!
cruizin4dirty1s
Tue Oct 22, 2013 12:23 am
Ill be doing the same swap as yourself in the near future have most of the bits together for it just wondering what suspension and brakes you are using ?
AndyZippy
Tue Oct 22, 2013 10:07 am
Yea kudos mate, very nice - You've made seemingly light work of the brakes, prop and engine mounts - Well done! I feel we need a video for the noise winkeye
m340
Sun Nov 03, 2013 12:03 pm
cruizin4dirty1s wrote:Ill be doing the same swap as yourself in the near future have most of the bits together for it just wondering what suspension and brakes you are using ?
The suspension is a bit of mix and match. At the rear are the trailing arms and disc brakes from an e36 compact, with a pair of z3m rear springs, and a e30 325i lsd diff.
The front suspension use's e36 m3 evo lower arms, koni adjustable shocks for a e36 328i, e30 320i anti roll bar and drop links, e34 540i springs (with 2 coils cut off), and e30 top mounts. The front brakes are e36 m3 evo drilled and vented discs, e36 m3 evo caliper carrier brackets, and e34 540i calipers.
Image[/img]
[/img]Image
Image[/img]
One of the front springs seems a little saggy, so I've just bought a set of koni springs from ebay ment for an e36 328i, hopefully get those fitted this week.
Also I think the rear discs may need upgrading to vented items, the solid ones cant seem to take a hard braking from speed! winkeye
m340
Sun Nov 03, 2013 12:06 pm
AndyZippy wrote:Yea kudos mate, very nice - You've made seemingly light work of the brakes, prop and engine mounts - Well done! I feel we need a video for the noise winkeye
Thanks, once the gearbox comes back from repairs I'll try and sort a video for you guys. :cool:
