So....I've the base/puck, the rear view mirror itself and a windscreen.....could you advise how do I attach the base to the mirror?
Cheers,
ADJ
Fitting convertible rear view mirror
alexdejonghe
alexdejonghe
Have u guys ever had the spring mechanism in the rear view mirror break? I got this mirror from the Zone a while back and it doesn't seem to want to fit onto my convertible base by twisting on....
alexdejonghe
With a loose base and convertible mirror if all was working correctly should I be able to easily twist these two pieces to sit together by hand? I'd just rather be confident in this before I glue the base onto my windscreen
Gavla
I used glass glue that I bought from Halfords. So far so good 2 years on. Do not use too much as it spreads when you push it on the glass. Be sure that it looks ok from the outside, ie even. I made the mistake of not checking mine. Hold it in place for a few minutes and then tape it to the windscreen with masking tape or similar and leave it to set. Give it a good 24 hours.
Yes, it should clip in by hand but you need to give a strong twist / push...
alexdejonghe
Thanks for the advice budGavla wrote:I used glass glue that I bought from Halfords. So far so good 2 years on. Do not use too much as it spreads when you push it on the glass. Be sure that it looks ok from the outside, ie even. I made the mistake of not checking mine. Hold it in place for a few minutes and then tape it to the windscreen with masking tape or similar and leave it to set. Give it a good 24 hours.
