Is the above compatible across the E30 range, apart from the struts obviously, for instance, will parts fron a 325i fit on
a 318i M10?
Would look and check on Realoem but for some strange reason
this is the only site on the Web I can access atm.
Everything swaps over except the springs, but even they'll fit if you're desperate. Of course, there are differences like roll-bar thicknesses, strut sizes, and non- or ABS hubs, but it all does the same job.
