Anyone fitted a sub?
Junglistjed
Thu Oct 10, 2013 10:54 pm
Just curious as to where you grounded the amp and how easier it was to get the power cable to the boot?
cheers
Kos
Mon Oct 14, 2013 11:14 am
All very simple
There are a couple of places you can feed the power cable through, if you pull the back seat out you'll spot them
As for the growns for the amp, you have several options. But the rear panel gives you the most options
www.pukardesigns.com
IG Pukar.Designs
polsta
Wed Oct 16, 2013 5:41 pm
a pre amped/active sub, is the easiest/cleanest no hasstle soloution, also easy to just whip it out/in if you need the boot space
