Engine conversion in uk
adamt93
Post Tue Oct 08, 2013 12:16 am
Fitting the v8 4.0l Wondering how much it would be for this conversion if I took it to a garage or a specialist to do? Thanks
LongR
Post Fri Oct 11, 2013 1:14 pm
there is not many people that would do it.. but if you are handy with tools its easy enough.
where are you located? would be helpfull to point any garages
m62 powered e30 in progress
adamt93
Post Fri Oct 11, 2013 1:17 pm
Birmingham area
LongR
Post Fri Oct 11, 2013 1:51 pm
i dont knoow of anybody around there.. closes i know to you is
http://www.gamacars.com/contact-us/
if not them... look more localy.. there is few people here im sure can do it for you.. i did mine.. it wasnt hard
DanTheMannn
Post Tue Nov 12, 2013 3:42 pm
"Bimmer bits" on FB Do any conversion and can supply engines etc.
Not used myself but have friends who have used them and recommend.
Located midlands somewhere!
Phill172
Post Wed Nov 13, 2013 10:23 am
Rob from Rawmotorsport will do the conversions,
But it depends on what your sourcing yourself, are you supplying a car, engine, box, manifolds etc
m340
Post Wed Nov 13, 2013 8:51 pm
It's not hard to do it yourself, the labour charge for getting a specialist to do the job would be thousands.
Just to give an idea of parts prices of a diy conversion:
-my 540i 6 speed donor car was £1100
-£800 on suspension and brakes
-£50 on 2 flanges and y peices to help make my exhaust manifolds
-£600 on a custom stainless exhaust from the manifolds back
-£250 on e30 an lsd
-£110 on a mercedes radiator and cooling fan
-£10 on metal offcuts to make engine mounts ect
-£50 on balancing the driveshaft
-£100 on rev counter chip from the states
-£500 on custom hoses for brakes and steering lines
The above list is what was needed to get mine driving, then you can upgrade as you see fit.
Darrenr
Post Wed Feb 19, 2014 7:00 am
Look at team sunset on facebook the guys have done mine and 4-5 other m60's in e30s and other is s bodys
sunnysr
Post Wed Apr 23, 2014 6:49 pm
How much did pete charge to fit the motor for you, was that a full job wires n everything
Post Thu Apr 24, 2014 1:24 am
Pete doesn't charge that much for the work above.
All he asks is that you spend some time in his basement with some "Werthers", and some pics. winkeye
