e36 brake setup
and1_e30
Post Tue Oct 01, 2013 2:28 pm
im doing an m52 conversion i have a full e36 2.8 convertible for the conversion i wanted better brakes can i use the e36 brake setup somehow?
cheers
jon
Andy325i
Post Tue Oct 01, 2013 2:41 pm
You can fit the E36 front legs and E36 ti (Compact) rear arms if you wanted to go to 5 stud wheels
and1_e30
Post Tue Oct 01, 2013 2:56 pm
cheers would I have to fit the front subframe and that what exacally would I need off the e36 to fit it? and if I used the subframe I wouldn't have to change the sump? and use the e36 steering rack with danthe uj`s?
Post Tue Oct 01, 2013 3:30 pm
I believe you need E36 M3 evo front legs otherwise the front geometry ends up bolloxed
Rallyprep_UK
formerly Driftnething
Post Tue Oct 01, 2013 3:32 pm
E30BeemerLad wrote:I believe you need E36 M3 evo front legs otherwise the front geometry ends up bolloxed
Agreed
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
and1_e30
Post Tue Oct 01, 2013 4:32 pm
ok cheers for the help guys will have to find another option :)
Motorhole
Post Tue Oct 01, 2013 4:36 pm
Agreed
Thirded. I have done this (E36 M3 Evo front legs & brakes).
