Hi
I recently bought some Lucas 550cc injectors for my m20 turbo project to run of megasquirt. Stupidly I didn't do proper research before getting them and it turns out they are 11mm on both ends rather than 14mm. I found some inserts for sale on an ausie site for the rail side which would allow these to be fitted but I am unsure if these could be used on the manifold end as well.
I know the simplest thing to do would be just to order another set of injectors that would fit without any messing about but I got a good deal on these and they've also just been cleaned and flow tested. Therefore if anybody has encountered the same problem I would appreciate if you could share your experiences.
Many Thanks
iain
11mm injector adaptors inserts
mongomushroom
ross2009
most people just order the right ones
mongomushroom
Good idea
mongomushroom
Havent seen any good used ones for sale just now so clutching at straws
ross2009
mongomushroom
Cheers bud
Quaser
they are pattern parts though - are they good?
makman
Ross haha
Canny Beat a chromie!'
makman
think il use them in mine too! they be good for mine eh ross?
ross2009
yeah be spot on for yours mate
