What discs??
etouring
Post Fri Sep 20, 2013 11:29 pm
Hi it's time to replace my disks and pads. Was thinking ebc yellow stuff. Has anyone tried them? Or should I just get the standard brembo? The ones in the car now fade really quick :-(
[/code]
Post Fri Sep 20, 2013 11:42 pm
replace and upgrade your brake fluid to a high boiling point variant ,the disc and pad set up is a long drawn out affair .
i'm running black diamond grooved/drilled discs ,red stuff pads, clio double diaphragm servo .
pagid pads and brembo discs are good for the 12v'ers apparently ?
etouring
Post Sat Sep 21, 2013 8:31 am
I've got the Cleo servo and 5.1 brake fluid but haven't tested it yet. Sorting last few things on moter first. Iim guessing there isn't much difference between the different sports pads. I'll sort a good set then. Thanks
