M20B23 Build
Steven320
Post Fri Sep 20, 2013 4:02 pm
Hi there,
Months ago i was planning to build a M20b24, sadley i canceld that project the parts that i need where not cheap or difficult to get.
so i changed my mind and i started with building a M20B23.
My idea is not making the most fastest 2.3l but more just a engine thats in my tast and budget. so here is the list with my ideas and after that i will post some pic's.
My inspiration started when i saw the Hartge H23 what extacly is 2.3l with high comp. pistons, wilder cam, headers and some head work.
I hope to get more horses then hartge claimd on there h23 or alpina's C1 2.3l. there whore running on L-jet or K-jettronic so i hope that the standalone ecu and some other changes bring me higher then there 170hp add the crank.
so fingers crossd
The list:
Rpm limit around .... Depends where the power will be
Raise the comp. till around 1:10.5 or 11
lighter and balancend pistons
lighter and balancend rods
balancend crank
lighter Flywheel
catcams 285 cam
36/42mm valves
30/45/70 valve job
some poort working
stainless headers
34.5mm custom made ITB
standalone ecu
bigger injectors
Pic's
so where do we start....
My work spot
Picked up my cleaned head with bigger valves
later today i will upload more pic's
greetz :mad: :mad:
Steven320
Post Fri Sep 20, 2013 6:20 pm
more pic's
im still busy with the poort work.
mean while i got my prototype piston back to check valve clearence. the right piston is from a m20b20. its also a lot heavier then my own prototype piston.
but my piston is going back to the shop for making the exhuast valve clearence bigger (2mm deep)but this pic is after i tested the clearence. the inlet valve hass 5 mm clearence so im gonna do the same with the exhaust valve so i can lower the dek bij 1mm or more.
