Wiper motor
tonybtonyb
Post Thu Sep 19, 2013 10:41 pm
Hi does anyone know if another wiper motor from any bmw will fit the e30.[/list]
Post Thu Sep 19, 2013 11:03 pm
E30 specific I am afraid. I can supply an excellent tested one with a guarantee :)
Post Fri Sep 20, 2013 12:10 am
There are wiper motors from other MAKES of car which are very similar to an E30 motor, and can be adapted to fit.
Have a look around a scrapyard.
Post Fri Sep 20, 2013 10:01 am
I'm also holding a fine example here.
Post Fri Sep 20, 2013 10:35 am
Don't worry Trev, he has got one sorted. Its off a '67 Scammell Contractor, but with a few days foooking about he might have wipers :)
johnono
Post Fri Sep 20, 2013 9:46 pm
quick question,..
my wipers are properly slow..
there is a slight improvement on stage 2, but not much.
No real resistance when the wiper blades are up, so it must be the motor right?
.. right :?
Post Fri Sep 20, 2013 10:10 pm
Common problem this. And getting more common by the day. They are getting old and weak now. A lube up may do it.
johnono
Post Fri Sep 20, 2013 10:43 pm
B7 wrote:Common problem this. And getting more common by the day. They are getting old and weak now. A lube up may do it.
Ill give it a go ;)
dave525
Post Mon Sep 23, 2013 7:43 am
mine were crap.Popped the motor out and did the procedure from the wiki and they are now like new.While the motor is off feel how tight the linkage is.There shouldnt be much resistance if any.
