m20 engine swap
robs
Post Sat Dec 17, 2005 7:10 pm
is there any diference in the head from a 320 montronic or my 320 jetronic? :D
Eddy
Post Sat Dec 17, 2005 7:28 pm
Hello to the zone 8)
The heads are identical,my LE-Jetronic M20 B20 has a motronic head on it and it works fine,the only diference is that the distibuter hole in front of the camshaft has to be coverd somehow....
otherwise,there is no diference to the heads...
Building my ultimate drift E30....
robs
Post Sat Dec 17, 2005 7:42 pm
thanks for the advice, so i take it you cant use the later block, due to the distributor, sorry if this is a daft question!
Eddy
Post Sat Dec 17, 2005 9:43 pm
No U cant use the latter block on the L or LE-Jetronic....but u can use the head....
