2.8 parts prices please
Looking for genuine BMW parts at discounted prices? Try here!
SlammedTouring
Post Thu Sep 05, 2013 2:13 pm
Hi
after a few service bits and gaskets, can get part numbers if needed. The car was a 1996 328i SE, trying to find the registration, can find the engine number if needed
Sump gasket
Inlet manifold gasket
Exhaust studs and nuts
Water pump and gasket/o ring
88* thermostat with gaskets and o rings
Rear water way gasket?
Plastic clip for the crank sensor cable
Alternator belt, complete kit with tensioner
And also
Gear selector seal
Gear shifter bushes
Rear wheel bearings for e30 touring
Rear brake seal kit x2 for touring
Jack
Cotswoldbmw
Post Thu Sep 05, 2013 3:35 pm
Hi Jack. Yes that would be good if you can use realoem.com and get part numbers. Thanks.
regards
Paul.
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
SlammedTouring
Post Thu Sep 05, 2013 4:13 pm
Hi
Hope these are right
Sump gasket 11131437237
Inlet manifold gasket Not needed
Exhaust studs and nuts 11121744057, 11721437202
Water pump and gasket/o ring 11517527799, 11511711484
88* thermostat with gaskets and o rings 11537511580, 11531740437, 11531265084
Rear water way gasket 11121738963
Plastic clip for the crank sensor cable 12141738742
Alternator belt, complete kit with tensioner 11281437929, 11281427252
And also
Gear selector seal 23121282394, 23121222677
Gear shifter bushes Unsure of number
Rear wheel bearings for e30 touring 33416762317, 33411138648, 33411125664, 33411124945
Rear brake seal kit x2 for touring 34211155716, 34111157038
Think that's everything
Jack
Cotswoldbmw
Post Thu Sep 05, 2013 4:32 pm
Dear Jack.
Thank you for your enquiry, the price for the parts required will be £637.12.
All prices quoted are for Genuine BMW Parts and include a discount for enquiring on line, VAT and no postage charge to a mainland UK address. If you need a price brake down please let me have your email address. Some of the parts will have to come from Germany.
There also is a surcharge on pump of £20.00 plus vat on return of old unit.
Give us a call to place an order on 01242 257999 and please quote reference number 44962
Regards
Paul
Paul Webb
Parts Advisor
Cotswold Cheltenham
Main Telephone Number: 01242 257999
Fax Number: 01242 257150
E-mail: partscheltenham@cotswoldgroup.com
Website: www.cotswoldgroup.com
Cotswold BMW Parts
01242 335365
SlammedTouring
Post Thu Sep 05, 2013 5:25 pm
PM sent
Cotswoldbmw
Post Thu Sep 05, 2013 5:28 pm
Hi quote sent. :D
Cotswold BMW Parts
01242 335365
