Few questions
Millhouse
Need to dash lights any info on taking the dash clocks out and when you 1st start it up if you put it in reveries it cuts out its an auto 316i the revs smooth out after a min once started any info on that would be great any my demist doesn't work the button lights up but that's it any help on theses would be GREAT
Grrrmachine
- E30 Zone Wiki / Team Member
1) Let's move this to the Technical forum...
2) No idea what you want to do to the dash, or why, but here's the removal procedure:
http://www.e30zone.net/e30zonewiki/inde ... eplacement
3) It cuts out when you select reverse? Is that from hot or cold, or every single time?
4) You need to see if 12V is reaching the rear window, and whether it's grounded properly. Use a multimeter.
5) Next time, full stops in your text would really be appreciated.
Millhouse
Thanks for the help and being disleix isn't easy that's why it's like that
And I need to change the lights behind my speedo . And only when cold
