E36 m3 throttle bodies and exhaust
SlammedTouring
Post Sun Sep 01, 2013 1:01 pm
Are these any good for a 2.8 engine if they can be made to fit or is too much hassle for the power gains?
Jack
Motorhole
Post Sun Sep 01, 2013 1:42 pm
Have looked into this. Seems throttle bodies foul the oil filter housing on m52 as s50s have a different setup with oil cooler. Exhaust won't fit without significant bodgery that would pretty much wipe out any real gains due to steering linkage etc.
SlammedTouring
Post Sun Sep 01, 2013 1:53 pm
Was just thinking about the exhaust for now, have Tig welders and all the gear at work (I'm a pipeworker/welder). Guess it would be cheaper than buying a stainless one but it is made for the job
reggid
Post Sun Sep 01, 2013 10:32 pm
i wouldn't use the S50 throttles, they are quite big so putting them on a 2.8L that makes 100hp less is mismatch of parts. Use the M50 manifold if you have a M52.
E30 325is with M20B31
frantic
Post Mon Sep 02, 2013 5:07 am
Has been done : M52Tu with s50 throttlebodies
http://www.bimmersport.co.nz/forums/ind ... opic=30332
I think it was 240hp to the wheels with more done but can't find the other build threads atm.
