hi all,
from countless searches it would suggest the pinion taps out
with a soft face hammer.
Now, I've been bangin on the pinion like a chimpanzee,
how much force should be necessary and is the end bolt the
only thing holding it?
cheers
al
Diff pinion shaft removal
gareth
It'll be in there bloody tight so 'tapping' is about 20% of what's necessary! If you don't have a press, refit the pinion nut so it's flush with the end of the threads so they're protected, place a bit of wood over the end. put the casing on the ground (on a bit of wood), not a bench. It needs to be firmly and rigidly supported or you'll be wasting energy. With a large hammer, whack the living shite of it!
Bingo
gareth
Yep
to be sure: you've got the flange off haven't you? ;)
If you can prize the seal out, try and direct a blowlamp onto the bearing. you're trying to heat the bearing to make it expand and loosen off the pinion.
gareth
That's properly brilliant!
Getting the races out is more a matter of tapping. work around them evenly with a punch and try not to damage the sides of the casing. if they 'bruise' then it'll need this damage dressing out to let a new bearing sit properly.
