Brake lining warning light
Motorhole
I know I can make this go out by connecting the yellow/green and white/blue wires in the sensor loom. But is this safe? Should I do it with a fusible link or just connect them together? Also there is a 3rd brown wire in the loom that doesn't appear to be connected to anything at the sensor end. What's best to do with this?
i just pulled the bulb out of the clocks mate .
+ a yard full of scrap turds
gnrsoul
If you still have the brake ware sensor just join both ends of the wires together and reconnect light goes out
fonk
if you after safe option and you dont often look at your brakes it will be the best to get sensor from ebay ,they only 3pounds....
...thats what i will do if my pads will go.
Motorhole
Sadly, not an option in my case - E36 M3 front brake setup. I could splice in the E36 sensor I suppose but then it would still throw an error missing the rear...fonk wrote:if you after safe option and you dont often look at your brakes it will be the best to get sensor from ebay ,they only 3pounds....
For now I've joined the wires via a 7.5 amp fuse to be sure and insulated the end of the brown wire. This showed no power and no continuity and it definitely wasn't part of the sensor plug so it seems it really wasn't connected to anything...
Just join the wires together
