touring rear side window removal?
Ag51bye
Post Tue Aug 27, 2013 7:26 pm
Hi guys,
Unfortunately as pictured my touring has a rust issue on the c pillar. is the black trim infront of the bonded window separate? or does it have to come out as part of the window?
Would be ideal if the black trim was separate, as that's where the access any tips on getting it out?
votivequagmire
Post Tue Aug 27, 2013 11:34 pm
Looking at the Realoem page it appears to be separate:
http://www.realoem.com/bmw/showparts.do ... g=51&fg=05
Hope this helps fella
'88 325i M20, could've done with a sunroof.
Jozi
Post Thu Aug 29, 2013 4:01 pm
The trim piece is bonded onto the window all along the edge that couched the glass (from memory) and there's a few blobs on the trim then as well holding it to the pillar.
Just so you know, the trim is nla (on one side anyway).
Ag51bye
Post Thu Aug 29, 2013 8:17 pm
cheers for the help guys. Jozi you were spot on, got it off in the end! its a bit damaged, but I can live with that!
Jozi
Post Thu Aug 29, 2013 8:19 pm
I ripped on of a scrapper to find out but I haven't thought of a way of getting it of undamaged, any tips?
I have a new one for one of the sides, the other one went nla between pricing and ordering :(
Have even been thinking of taking a mould of it and making it out of fibre glass.
Ag51bye
Post Fri Aug 30, 2013 11:35 pm
I just used a bit of wire in a sawing motion up the side, must admit I bent it a bit :(, but i`m not a perfectionist, as long as it stays on the road and looks presentable i`m easily pleased!
**BANNED**
Post Sat Aug 31, 2013 1:46 am
I could do with a n/s one,if that's the side you are thinking about making.
Jozi
Post Sat Aug 31, 2013 11:19 am
If I went for it I would do both sides :thumb:
