M52 steel water pipe
SlammedTouring
Post Mon Aug 26, 2013 10:31 am
Hi
Moving my m52 engine and the steel water pipe caught on something and now it's able to twist easily
is this going to leak and if so how can I fix it?
Post Mon Aug 26, 2013 9:08 pm
Its only sealed to the block with 2 O rings, so yes it will twist easily, nothing to worry about though
SlammedTouring
Post Mon Aug 26, 2013 9:10 pm
Great thanks, wanted to know now while the engine is still out and easy to get to
Andy325i
Post Tue Aug 27, 2013 1:31 am
If your going to replace the O rings the part number is 11 531 703 848 x 2 @ £1.75 each and it's worth checking the pipe isn't rusty underneath
SlammedTouring
Post Tue Aug 27, 2013 8:20 am
Do I just pull the pipe out to remove it?
randomspeedfreak
Post Tue Aug 27, 2013 11:21 am
SlammedTouring wrote:Do I just pull the pipe out to remove it?
yes
