lsd Rebuild ??
BATTS91
Post Wed Aug 21, 2013 1:37 pm
My pal has a lsd that has a bearing wine coming off load . Is this common .?
Also does anyone have contact details for Gareth ? To rebuild/fix problem .
Thanks [/list]
TSM3
Post Wed Aug 21, 2013 2:15 pm
Not sure if it's common but mine has the same whine and have been told it will still last for ages so shouldn't be an issue.
gareth
Post Wed Aug 28, 2013 7:16 pm
Whine off power usually pinion bearings. once they whine, they wear out a lot faster, mainly due to the metallic grinding paste the bearings make while chewing themselves up. This also trashes clutch plates and all other bearings and moving parts.
PM me through here if you'd like to discuss rebuild prices etc :)
