Having recently done quite a bit or rewiring including replacing the Dash etc.. I want to check the alternator is charging the battery.
Is there a simple place I can test with a volt meter to confirm, or maybe another similar test.
Richard
Checking the alternator is charging the battery
Black_Potato
3x S14 Rightness....
maxfield
Stick your volt meter on the battery when the engine ia running. Should be somewhere between 13.8-14.4V
maggspower
- Turbo Farmer Tractor Driver
Get a multi meter, check the voltage at the battery, should be somwhere around 12.5v
Next start the car, repeat the test with the car idleing. The reading should now be somewhere around 14v. This way you are checking the alterator and the wires in the charging circuit.
HTH
HTH
Contact: theengineshedonline@gmail.com
Black_Potato
That was obvious, there was me looking for something complicated
Thanks.
Thanks.
milescook
As you've done dash work, make sure the battery light is wired up otherwise it won't charge at all
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
