Hi guys
Is it possible to use facelift injectors in a pre facelift engine?
I bought a '84 320i which has been running on LPG for a long time. Now it runs like *** on petrol. I've already drained the old petrol and put fresh one in it with injection cleaner and installed a new petrol filter.
I want to go to the MOT and I don't want to wait till the cleaner kicks in (or doesn't). I still have 6 good facelift injectors lying around so I was wondering if they would work.
Facelift injectors in a pre facelift car? M20B20
- E30 Zone Wiki / Team Member
1) No, there's a difference in the impedance of the injectors. Fitting the wrong ones could potentially fry the ECU
2) Injector cleaner in the tank will do the square root of f**k-all to the state of your injectors. Remove them and send them to Injectortune if you want them cleaned.
- Brianmoooore
Obvious solution is to keep it running on LPG. The engine will thank you for it, and you should be able to pass a cat. spec emissions test in the MOT, just just the older one it has to meet.
1) Thanks, but I checked RealOEM in the meantime and the injectors should be the same for a '84 320i and for a '88 320i. Not if one of them has a cat, then there different.Grrrmachine wrote:1) No, there's a difference in the impedance of the injectors. Fitting the wrong ones could potentially fry the ECU
2) It seems like that yes. It's not worth it to me to send them of, theres an M50 waiting to go into the car. I just need to pass the MOT with this engine and drive it for a couple of weeks maybe.
No can do. I live in Belgium and I want to get it registered as an oldtimer which means only 1 MOT check and that's it. Never again until it switches owner. But with LPG, you have to get it checked annualy. I don't want that because I'm going M50 soon and engine swaps are not allowed hereBrianmoooore wrote:Obvious solution is to keep it running on LPG. The engine will thank you for it, and you should be able to pass a cat. spec emissions test in the MOT, just just the older one it has to meet.
