Hi all, I've just purchased a clean 316 and am looking to do the 2.5 engine conversion. i have had a look but i cant find a thread which tells me the parts i need. I'm looking to do this conversion as this is one of the most clean shells ive ever seen with no rust and only 65,000 miles. Any help would be greatly appreciated as i am new to the BMW scene
Many thanks
316 to 325 Conversion
adamt93
To be honest mate its a plug and play all you need is engine exsaust and the gearbox ohh yeahh and the loom but the loom will be the same plug and play straight in one of the easyest swaps to do ohh and don't forget you need alittle bigger brakes ;)
jmc330i
Easiest way to do it would be to buy a rotten 325i. You'll have everything needed to just swap over, including the larger front struts and rear disc arms (unless your 316 is a touring, you will need these).
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
