clutch
Sx279
Post Wed Jul 17, 2013 9:57 pm
e30 316 with m52b28
dos anyone have a part number for a clutch when using a m20 flywheel with a e30 325 box?
i was under the impression it was a getrag 260 as i had to make the mount up but now i have checked the side of the box the number on the casing is 240.0.0.0130.91 which has lead me to believe it may be a getrag 240 but i know it came from a 325 m20.
i ordered a clutch for a 325 e30 but the clutch plate is completely wrong on the splines same number but wrong size
and the spring plate dos not fit the flywheel
any ideas boys?
jmc330i
Post Wed Jul 17, 2013 10:27 pm
You could have a 320i box. I'm sure the 320i box is a 240, but can be used in the 325i - many do as the ratios are close to the Sport ratios.
Any pics of the flywheel and clutch? Will help with identification.
James
'91 325i Sport
'93 318i touring 16v
Sx279
Post Wed Jul 17, 2013 11:04 pm
ill get some pics tomorow when im at work cheers make
