Clutch master cylinder gone again!
jackolanton
Wed Jul 10, 2013 8:47 pm
Just a heads up to avoid this particular part.
My clutch master cylinder went about a couple of months ago, I was pumping the pedal all the time to generate enough fluid pressure in the system. Anyway... It was replaced less than 500 miles ago (about 4weeks) and now its gone again.
Parked up fine, went in to a mates for an hour, came out. Clutch pedal was on the floor. After a poke about under the dash i noticed it had snapped at the top, where the cylinder connects to the top of clutch pedal near the coil return spring . The loop at top of piston rod and the rod itself have parted. Im guessing its failed under compression ie, stamping on the clutch pedal(i don't mean excessively)
GSF PART
E30 325i CLUTCH MASTER CYLINDER
Item Number 716BM0032
Avoid it like the plague.
Hopefully i'll get it sorted in time for The German Show. Want to have a bash at it myself, but don't have the equipment to bleed after.
Quick question.
Should I do the slave at the same time, Ive not noticed any issues disengaging.
Thanks for any advise :)
How do I upload a picture?
Pursuant of knowledge
bigbird76
Wed Jul 10, 2013 9:37 pm
Slave should be done the same time yes.
Febi/bilstein do master and slave cylinders which should be decent enough for your car.
Bleed the clutch like the brakes, If I remember correctly all you need is a 8mm spanner and a length of clear pvc/rubber hose to bleed the clutch.
Leigh
G-Bear
Thu Jul 11, 2013 7:45 am
Bad news about the master. Its a fiddly job to replace yourself but fairly straight forward.
I used this method to bleed my system, worked pretty well
[youtube][/youtube]
jackolanton
Thu Jul 11, 2013 8:56 am
Thanks Leigh, I'm looking for one from them now. winkeye
G-Bear - that video is brilliant, just need to get the pump he has. Cheers for that, makes it all very clear. :)
Thu Jul 11, 2013 9:10 am
You can reverse bleed the clutch hydraulics by connecting a tube between the bleed nipple on the front left brake caliper and the clutch slave bleed nipple, then pumping brake fluid back through the system.
jackolanton
Thu Jul 11, 2013 9:18 am
I'm struggling to find a Febi/bilstein one, except from the USA and threw ebay, so i'm concerned it might be a fake.
Anyone know where I can get hold of one today?
What's the original BMW one like?
Thanks again
Meatballs82
Thu Jul 11, 2013 9:32 am
Nothing wrong with Pagid cylinders, check carparts4less mate
jackolanton
Thu Jul 11, 2013 9:36 am
Brianmoooore wrote:You can reverse bleed the clutch hydraulics by connecting a tube between the bleed nipple on the front left brake caliper and the clutch slave bleed nipple, then pumping brake fluid back through the system.
Does that mean that the fluid is bled round through the brakes from the reservoir, will it not take forever? Should i clean both connects between the tubing to avoid any gunk getting in?
Makes perfect sense, just Im not a mechanic, Ill have a go at most things, but until im underneath seeing it, sometimes it dont register and the light stays out :)
Still struggling to find a decent part
jackolanton
Meatballs82 wrote:Nothing wrong with Pagid cylinders, check carparts4less mate
cheers on it now!
Thu Jul 11, 2013 9:43 am
http://www.carparts4less.co.uk/hydraulic-clutches
Make sure everything is clean if you reverse bleed.
jackolanton
Thu Jul 11, 2013 9:56 am
Brianmoooore wrote:http://www.carparts4less.co.uk/hydraulic-clutches
Cheers, just ordered for next day delivery.
Thanks for the help and advise people, If i get stuck Ill be back on to ask for help again - Saturday is planned :roll:
G-Bear
Sat Jul 13, 2013 12:41 am
I used one similer the ones listed here..
http://www.amazon.co.uk/s/?ie=UTF8&keyw ... grfdyigj_e
