no rev gauge .help
frenchi
rev gauge not working as checked from 101 plug, no 6 as black wire, but other side of plug to engine no wire to pick up from,nothing on the other side of 6, where on engine does rev wire come from to connect to no 6 black wire ,hope you can understand this,,,help its driving me nuts
Grrrmachine
- E30 Zone Wiki / Team Member
You've got multiple threads about this, and you've PM'd me, so lets put all this in one place.
Your car started life as a 1989 318i auto (not an SE, there's no such thing as a 4-pot SE). You've put in an engine from a 1986 325i Manual. I presume the rev counter stopped working AFTER the swap, although you haven't told us that.
When you swapped the engine, you swapped the engine loom, which means disconnecting things at the C101 plug. Now your new engine loom does not have a black wire at pin 6. Cars after 1987 should, and this runs to the ECU, but because your engine and its loom are older than this, you do not have that wire.
Find your ECU, and look at the big plug it connects to. Coming off that plug should be a smaller plug with three pins. Pin 1 should have a blue/black wire - you need to connect this wire to Pin 6 of the C101.
frenchi
I am sorry for the righting I have a few probs seeing and then righting ,but I am glad you understood .will try this right now ,thanks ,thanks again
Grrrmachine
No problems
frenchi
well don't know what to say ,but thanks.,,, thanks again ,, ,you the man ,,,,
If you had mentioned in your other thread, on exactly the same subject, that the rev. counter had NEVER worked with this installation, then I might just have come up with the same solution! In the absence of information to the contrary, I tend to assume that things not working have recently stopped working on its own, not failed to work after major alterations.
