Power roof problem
AndyTouring
Post Mon Jul 08, 2013 11:06 pm
My friends power roof went bang (literally) some time ago & now they're finally getting around to fixing it.
One of the rods on the right hand side that push/pull the roof has bent 90 degrees then snapped. Can anyone with a power roof take a photo of the two rods that run from the rear pivot forward to the roof mechanism. I'm struggling to see where the broken one should attach.
We think the roof frame may have twisted & jammed while the the motor kept pushing, forcing the rod to bend before finally snapping.
AndyS
Live each day as if it's your last because one day it will be.
Gert_8
Post Tue Jul 09, 2013 10:03 am
These are the parts.
http://www.realoem.com/bmw/showparts.do ... g=54&fg=10
I've had a look through my library of pics, but don't have any showing the rods connected to the roof end (these are the ones you're after right?).
I'll take one tonight, if no one posts something up in the meantime.
AndyTouring
Post Tue Jul 09, 2013 9:42 pm
This is 'part 3' although it's no longer straight!
I think it attaches to the bracket visible just above the nut on the compartment floor.
Then there's the question of why it went wrong in the first place.
AndyS
Gert_8
Post Wed Jul 10, 2013 7:37 pm
I've got two pics for you Andy. I'll post them first thing in the morning. I thought I'd be able to upload from my mobile photobucket, but obviously I cannot..
In the meantime, rod #3 should have a swivel joint on the end of it. This then connects to the middle lever in the pic you posted. The second one in if you count from the right.
Gert_8
Post Thu Jul 11, 2013 9:10 am
There you go. Yep, bit paranoid about the lube..! :D
