can you still buy new exhaust heat shields?
scjimbo
Sun Jul 07, 2013 12:46 pm
As above.
If so how much?
Sun Jul 07, 2013 1:45 pm
If you mean the bits that protect the ignition leads from the exhaust manifold, then yes. You get one free with every exhaust manifold gasket, since they are part of the gasket.
Rtaylor2208
Sun Jul 07, 2013 3:08 pm
Cotswolds have them for the full underneath of the car but there not cheap.
scjimbo
Sun Jul 07, 2013 3:48 pm
I was on about the ones that run the length of the car. They seem to be mighty spensive though :(
zd3bx
Sun Jul 07, 2013 5:49 pm
Yes, you can still buy them from BMW.
Here > http://bmwfans.info/parts/catalog/E30/4 ... nsulation/
Check the prices here > http://www.cooper-bmw-parts.co.uk/
For example, item 1 is £43.10, which I think is not too bad...It wouldn't be a tenner for sure lol
scjimbo
Sun Jul 07, 2013 6:03 pm
zd3bx wrote:Yes, you can still buy them from BMW.
Ah those prices are more realistic. On the other thread it was 200 quid
Sun Jul 07, 2013 10:30 pm
Never seen a #1 that has deteriorated in the slightest. A second hand one should be absolutely fine.
#8 is a different matter - this needs replacing on nearly every E30 I've seen, and is a frequent cause of exhaust rattles.
scjimbo
Sun Jul 07, 2013 10:37 pm
It's the number 8 I need it's rotten beyond belief. It has a nasty effect on my OCD
