bottom control arm
listere30
Post Sat Jul 06, 2013 5:46 pm
What's the quickest and easiest way to do them?
Any links to a how-to guide or anything?
Sorry if this has been previously asked its just a mess on using me phone for searches
Thanks in advance
milescook
Post Sat Jul 06, 2013 6:05 pm
My advice for the ball joint seperation is forget hammers, pickle forks etc. Use a proper scissor type seperator.
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Jul 06, 2013 7:10 pm
I'd agree with miles. I've done this job a few times and a ball-joint separator is a must.
listere30
Post Sat Jul 06, 2013 9:07 pm
Ball joint isnt the issue, its the part that bolts through the subframe
What is the best way to tackle this?
again is there no guides or nothing?
GB69
Post Sat Jul 06, 2013 9:58 pm
hit subframe with hammer, it always pops out eventually.
Grrrmachine
Post Sat Jul 06, 2013 10:23 pm
Not many guides out that tell you how to undo five bolts. But essentially if either joint won't pop out, then screw the nut back on to protect the thread and then belt it with a hammer.
listere30
Post Sun Jul 07, 2013 10:26 am
Is dropping the subframe the only way to get access to the nut?
I presume so but worth an ask lol
Grrrmachine
Post Sun Jul 07, 2013 11:08 am
Never heard of anyone dropping the subframe to do this job! However, the last time I did it I used about a metre's worth of socket extensions to get the inner joint nut undone, by undoing it from above the engine with a breaker bar.
macas
Post Sun Jul 07, 2013 11:18 am
Grrrmachine wrote:Never heard of anyone dropping the subframe to do this job! However, the last time I did it I used about a metre's worth of socket extensions to get the inner joint nut undone, by undoing it from above the engine with a breaker bar.
That's right,if you have a pit you can replace the arms without actually taking the wheels off.
BHadley
Post Tue Jul 09, 2013 12:15 pm
I had to remove the exhaust on my old 318i to get the drivers side nut off the subframe. Passenger side is easier and I used a ball joint breaker like a two prong fork and a lump hammer plus lots extensions and AirTunes and impact sockets, 22mm I think for the deep socket....
BHadley
Post Tue Jul 09, 2013 12:17 pm
Sorry that's air gun not AirTunes, blame apples anal spell help!
