engine steam clean
stevo
Sun Dec 11, 2005 1:37 pm
is it wise to steam clean an engine? i found a tin of gunk, engine cleaner in my dads shed so i "borrowed" it and was wondering what bits i need to cover up on the engine before giving it a blast.
the only obvious things to me is the alternator and ignition coil, the fuse box has the cover on it and the diagnostic/service light jobby has the screw on cap on it. is there anything else i should cover or avoid scooshing directly, like HT leads? its an m40 engine.
also whats the best thing to use to cover up things?
i tried this on my nova once many moons ago and it didnt start until i sprayed wd40 on everything, but nothing was covered up :oops:
cheers in advance
smithy318i
Sun Dec 11, 2005 1:43 pm
Iv'e jet washed my engine (M40) before with no ill effects.
If your worried about the electrics, cover them with bin bags.
stevo
Sun Dec 11, 2005 1:52 pm
cool, i'll be doing it at work at somepoint this week, fingers crossed i won't be getting the b*s home! :clin:
m-dtech
Unapproved Trader caution
Mon Dec 12, 2005 2:02 am
a dry steam cleaner is a good way to get dir of dirt.
squeal
Mon Dec 12, 2005 2:43 am
cling film is ideal for covering the areas mentioned
squeal
