car leans to one side
E30k
Sun Jun 30, 2013 1:08 pm
this problem has been on my head for some time and i keep putting it off so other than taking every thing out what do i need to look for the car has been lowered by 40mm as far as i can tell all looks installed correctly only odd thing is on the drivers front side which its leaning on the the spring is more compressed than the other side is this normal if not what could cause this and any other ideas in sorting it out would be helpful cheers
adamt93
Mon Sep 02, 2013 9:17 pm
The best thing to do is check all four tyre pressures and then measure the top of the tyre to the wheel arch and if it measures up the same then it's normal if it doesn't it would be a fault with the one that's lower
verde
Mon Sep 02, 2013 9:18 pm
driven by a fat cunt?
Raise hell praise Dale.
