Breaker bar removal type.
How do I lock the engine/flywheel up?
No electrics, so can't use starter motor method.
Crankshaft bolt removal .325i Engine still in car.
gooner1
- Out humping Reindeer
- **BANNED**
Wedge an old screwdriver in the flywheel ring gear via the starter slot?
If the starter is still fitted,it may be easier to use a battery and some jump leads to trigger the starter...
Youth is wasted on the young.
AdamBeevers
remove starter and do as stated above
