Hi, decided to track a noise coming from the engine, near the camshaft belt / water pump area. It is rpm depended and sounds like a rubbing sound between metals.
Timing belt with tensioner was replaced 3 years ago / 20000km, water pump was replaced 9 years ago.
What do you think? If you carefully listen at 00:36 it is more intense.
Link:
Does this sound like a failing water pump?
DanTheMannn
pump should always be replaced with belt, i'd change it anyway bud!
BHadley
Sounds like my old m40 318i...... So yep I'd say water pump, cured my noise and a nine year old pump is going to be tired. Easy enough to change once the fan blades are off, don't be surprised if the old pump has to broken with a hammer if its stubborn to remove
paris
Thanks for the replies! Will go ahead and replace the WP, for some odd reason since 1989 all of them have been failing between July/August
paris
Managed to get it out, somehow
Bearings were shot, this is the 4th or 5th WP
BHadley
Wow, quite worn! Has the noise gone with the new pump on?
paris
Yes it's gone, engine's quiet again. This one had a lot of play, I'm surprised it didn't ruin the fan / belts.
