3.91 LSD Oil ?
no1_jazz
Post Wed Jun 12, 2013 4:43 pm
Hi zoners,
Which oil do you all reccommend for my 3.91 LSD?
It is in my 318is which is used for motorway cruising and your occassional drive to town.
I have had a look at http://www.opieoils.co.uk and they reccommend the following:
Castrol Syntrax Limited Slip 75W 140 (Formerly SAF-XJ 75w-140)
Has anybody used this oil and or should I be looking at another oil?
Thanks in advanced
Jazz :cool:
BenHar
Post Wed Jun 12, 2013 4:49 pm
Why wouldn't you use the oil recommended in the stickied post on the zone?
Ben
no1_jazz
Post Wed Jun 12, 2013 4:56 pm
Hi Ben
what oil is recommended and do you have the link ?
j
maxfield
Post Wed Jun 12, 2013 5:02 pm
Castrol syntrax is the oil that's recommended
no1_jazz
Post Wed Jun 12, 2013 5:04 pm
Cheers Max
This is the one to go for then :
Castrol Syntrax Limited Slip 75W 140 8)
maxfield
Post Wed Jun 12, 2013 5:11 pm
Yes correct.
no1_jazz
Post Wed Jun 12, 2013 5:12 pm
Top man thank u :cool:
BenHar
no1_jazz wrote:Hi Ben
j
It's in a sticky at the top of the section of tha forum that you have posted this to.
Ben
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Jun 12, 2013 5:38 pm
There are THREE stickies in this forum about oil, as well as the Wiki. This is what happens if you type "OIL" into said Wiki:
http://www.e30zone.net/e30zonewiki/inde ... fferential
no1_jazz
Post Sat Jun 22, 2013 11:38 am
Cheers Grrrmachine.
Can anybody confirm how much i am going to need?
e30zone wiki states 1.7 liters required for large (medium case dif)
a garage local thinks i am going to need 2.5 liters of oil to go in my 3.91 lsd.
strange.
Motorhole
Post Sat Jun 22, 2013 12:19 pm
Wiki is correct. Not-quite 2 bottle's worth, did mine a couple of weeks ago from dry. No way will you need 2.5 litres.
jimbom30cab
Tech 1 freak
Post Sat Jun 22, 2013 12:23 pm
Me also and it used a mug less than 2L
About 1.7L I would say
no1_jazz
Post Sat Jun 22, 2013 12:30 pm
Thank you for clearing this up guys.
