318 spluttering
paul007
Post Tue Jun 04, 2013 11:12 pm
i have a 318i convertible
i was on the motorway yesterday and out of the blue it started spluttering -when i accelerated it retarded even more.
when i stopped it was idling fine -however when i drove off again it jerked and spluttered to the point i thought it would stop.
i called the rac but by the timed they arrived the car was ok. however he unscrewed and screwed back the airflow sensor cap saying this can be a problem sometimes.
today it started spluttering again as i was driving, so i stopped and unscrewed /screwed back the airflow sensor cap. the car was ok for a bit then it started again.
any help greatly appreciated.
:( :( :( :( :( :( :o :( :cry:
Post Tue Jun 04, 2013 11:23 pm
Could be all manner of things, ranging from a dodgy batch of fuel, blocked fuel filter, perished fuel hoses, failing spark plugs/distributor cap/rotor arm/ignition coil, loose engine-to-body earth strap, failing DME relay, etc.
You need to methodically go through and check these.
Billwill
Post Wed Jun 05, 2013 9:09 am
What is an airflow sensor cap?
Is this an M40 or M10 318i? :?
paul007
Post Wed Jun 05, 2013 10:11 pm
its a m40 and the cap is the tube that joins the air flow sensor i guess you have to unscrew it to take it off.
i think it defo has something to do with that as now when it starts to misfire when i unsrew and srew the cap back on its ok for a while.
