m40 to m20
dje30
Post Mon Jun 03, 2013 9:35 pm
hello guys
Ive been offered at m20b25 engine and box today
Ive been told its a high comp engine / early one?
i currently have an m40 1.8 in my 1989 e30 at the moment
I know i need the
engine and ancilaries
gearbox
gear linkage
prop shaft
loom
ecu
exhaust
is there anything im missing?
any pit falls i should avoid?
thanks
dave
maggspower
Turbo Farmer Tractor Driver
Post Mon Jun 03, 2013 10:47 pm
Hi there Dave, to add to your list: Diff, not strictly necassary but good to have the right ratio. Cooling system, you can make your current rad work with some imagination. A few extra brackets in the engine bay for relays and the air box, these will make it look factory rather than a cable tie effort, unless thats the look you are going for :D Six pot plug for the clocks, this will make the tach read correctly. Six pot suspension, as it will be up to carrying the extra weight up front.
It would also be agood time to swap to the later engine managment, and complete any servicing work while the enging is out. Things like the cam belt and changing the sump gasket, are just easier to do with the engine not in the bay.
HTH
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Jun 04, 2013 6:43 am
leeharrisom
Post Wed Oct 09, 2013 9:58 pm
cheers
this is essential for anyone thinking the same :)
http://www.e30zone.net/e30zonewiki/inde ... Swap_-_M20
Post Wed Oct 09, 2013 10:18 pm
An early high compression engine will have 25 6K above the engine number (stamped into a machined flat on the block to the right of the inlet side engine mount).
It should also have the 0 261 200 073 ECU, although some later ones (1988 year) had the later Motronic 1.3 0 261 200 173 ECU.
