ABS / Non-ABS Handbrake cable difference?
TheDutch
Post Sat Jun 01, 2013 1:46 pm
Just shopping for new handbrake cables and see that some are labelled for ABS equipped cars, and some for non-ABS. Both are the same length (1725mm), is there actually any difference between them?
Post Sat Jun 01, 2013 9:06 pm
You get exactly the same thing when shopping for braided brake hoses. The difference is rear discs versus rear drums, not ABS or not.
TheDutch
Post Sat Jun 01, 2013 9:11 pm
Thanks both, I thought that would be the case. They're only £6 each for Bendix (which should suffice) so not too worried about them not fitting.
