Alternative Engines?
cee
Wed May 29, 2013 2:23 pm
So I'm toying with the idea of doing something crazy/different. Maybe Volvo? Any ideas/suggestions?
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
ross_jsy
Wed May 29, 2013 2:42 pm
Seen a few Volvo conversions before, the turbo lumps can make decent power apparently.
But then so can a lot of BMW lumps so not sure if I would bother given the added hassle
ross2009
Wed May 29, 2013 9:30 pm
crazy different ??
1jz or rb25 ???
Turbo M20
v8 project 6.0 twin turbo
Wed May 29, 2013 9:41 pm
There's a Touring on here with a Saab Turbo enigine
appletree
Wed May 29, 2013 9:44 pm
volvo lumps are built well there are some stupidly powerful ones from norway but i dont think there such thing as a crazy swap in an e30 other than somthing exotic no a days
taylorstattoo
Wed May 29, 2013 9:45 pm
theres one on ebay at the moment with a skyline motor fitted, bet that would be fun winkeye http://www.ebay.co.uk/itm/BMW-E30-RB25- ... 3cd20b7cad
cee
Wed May 29, 2013 11:08 pm
Jap engine in a German car? No way. Other than that I'm easy. Saab, Volvo, Alfa etc. are all cool. Just wanted something a bit different that would give a good project rather than just plugging a generic BMW engine in.
Gunni
Wed May 29, 2013 11:39 pm
First you might want to ask yourself what is the purpose of the car?
Motorway cruiser/warrior or in town cruiser ?
In general there are no new engine swaps to E30´s. Just about all have been done.
It´s just down to what you want your project to be, making bits, researching and solving, wiring, standalone or whatever.
Gunni
@ 2012 VEMS group buy !!
leeparkes
Wed May 29, 2013 11:44 pm
I remember a thread with an Audi V8, one of the later engines.
Wed May 29, 2013 11:46 pm
Has anyone ever fitted an Alfa Romeo/Fiat/Lancia twin cam in one?
davethegoat
Wed May 29, 2013 11:55 pm
I was thinking of a 4G63 Mitsubish Evo engine in mine at one point. This, from a link in S62 engine swaps on here: http://e30m3b-spec.blogspot.co.uk/ :cool:
78gizmo
Sat Jun 01, 2013 1:37 pm
I have always wanted to do a Volvo T5 (850 or V70 5 cyl turbo) engine swap. Big power for little cash, I love the 5 pot noise and I think some of the older rear wheel drive volvos(960 / 940??) uses the same bell housing pattern, so that's most of the drive train sorted out!
Andy325i
Sat Jun 01, 2013 2:00 pm
cee wrote:Jap engine in a German car? No way.
Not sure of his driving though!
Sat Jun 01, 2013 7:09 pm
That's bloody qiuck 8O
cee
Sun Jun 02, 2013 10:28 pm
78gizmo wrote:I have always wanted to do a Volvo T5 (850 or V70 5 cyl turbo) engine swap. Big power for little cash, I love the 5 pot noise and I think some of the older rear wheel drive volvos(960 / 940??) uses the same bell housing pattern, so that's most of the drive train sorted out!
That's more along the lines of what I was thinking! Thanks :D
jmc330i
Mon Jun 03, 2013 12:25 am
Volvo T5 isn't so easy, or an easy way to get the right side of 300bhp. Many on the Volvo forums will tell you, 280-300bhp is the most standard internals will take - an M50 will do that all day long as standard.
The 960 M90 gearbox will bolt straight up to the 5pot, although I've been told it isn't good at taking abuse. It's worth noting there were two versions of the RWD M90 box, the Volvo 940 version won't fit the 5pot, but will fit the 4pot. It apparently is stronger than the 960 version, but I don't know how or why.
The sump is a big issue. You can chop the middle section out of the 960 6pot sump, but the bowl is still in the wrong place for the E30 subframe/arb, so more cutting and modding is needed. I know of one guy who built his own sump using the FWD sump for bits.
The dizzy cap also presents problems. It's fine for big power (500+bhp has been done on the standard management/dizzy), but its placement at the back of the head puts it right in the way of the E30s bulkhead.
The later T5s use coil packs, but the later engine management is sketchy in the Volvo it was designed for, let alone trying to get it working in an E30, so a standalone ecu will be needed.
Seems a lot of work for maybe 280bhp, when a turbo M20 will do that without the hassle of trying to get the engine to fit.
Still doesn't stop me wanting to try it though.... I do have a T5 engine after all winkeye
James
'91 325i Sport
'93 318i touring 16v
cee
Mon Jun 03, 2013 12:32 am
jmc330i wrote:Volvo T5 isn't so easy, or an easy way to get the right side of 300bhp. Many on the Volvo forums will tell you, 280-300bhp is the most standard internals will take - an M50 will do that all day long as standard.
Thanks for the details. It does sound a lot of hassle when I could be bolting an m52 in there...
handpaper
Sun Aug 04, 2013 12:47 am
For a track toy I'd consider a Mazda Wankel - decent power, turbo well if you want to, and light weight and compactness should help with the weight distribution (stripped e30s get very front-heavy)
