Post
Wed Jun 05, 2013 4:51 pm
had a nightmare with mine, had no issues when car was on the road, it was ll in place, thought remove it for a clean up- thats when the problem started, it was all sealered on wiht thick gasket stuff, and the bottom stud was all water corroded in, took about 4 attempts, with penetrating fluid,leaving, trying again next day etc, eventualy got it off, and had to get a blow torch and mole grips and that took a while, to remove the stud from the head, lucky enough it all ended up ok, got a replacement housing and new studs in the head, on the flip side it was lucky i took it off and didnt leave it to corrode more and end up with big troubles lateron
so is this delete thing the way to go ?
